Hondata 06/07 reflash
Old Sep 19, 2007 | 06:31 PM
Boofster's Avatar
Default Hondata 06/07 reflash
Does anyone know if the Toda reflash works with other headers like J's or Comptech?
Old Sep 19, 2007 | 07:24 PM
negcamber's Avatar
Probably a good question to send to Hondata. Or check out their forum on their website to see if someone else asked the same question.
Personally...I think it would work OK...but likely not to be optimized for anything other than the Toda. Still...given that each car is different, their tuning tollerances must be broad in order to make sure the variance between cars wouldn't create a too lean situation.
Old Sep 19, 2007 | 07:29 PM
RedChili's Avatar
"While we will not create custom tunes for any other combinations of bolt on parts, other headers will probably be ok. You should always dyno the engine with the reflash to make sure the air/fuel is within a safe range. If the header does not work then your options are to switch to a Toda header or return your ECU to stock." From their website.
Old Sep 19, 2007 | 09:57 PM
Boofster's Avatar
So there is a way to disable the "mod" I guess. Interesting. I wonder if they just solder a chip socket like the old B-Series ECU's.
devs2k
Jan 12, 2008 04:20 PM
blkblks2k
Socal Swap Meet
Nov 10, 2007 09:22 PM
2004S2000
Jun 20, 2007 01:20 PM
AJS2K!
May 5, 2007 03:22 AM
SilentWhiteNoise
Aug 17, 2006 04:28 PM
