hondata gasket installation
You could've dropped a nut or bolt into the intake runner, which would fall on top of one of the valves. When you crank it up, either the nut/bolt will fall into the combustion chamber, or it will snap the valve and that will drop into the combustion chamber. Either way, your piston will probably shatter, you'll throw a rod and punch a giant hole out the side of the block.
You may also lose oil pressure.
Originally Posted by alexf20c,Aug 17 2004, 10:49 PM
I'm sure everything will be fine.
You did, after all, ask for the worst-case scenario.
