Hondata IMG
For those who have the Hondata Intake Manifold Gasket (IMG), and have had your car dyno'd since having the IMG installed, can you please tell me what power gains you achieved?
There is no gain there.. simply a reduction in the impact of heat.. you may have less loss from heat and timing retard.
Also, if you go to Hondata's site, they state:
"Hondata have developed a special high temperature insulating gasket which replaces the stock intake gasket. This and bypassing several heat sources significantly reduces the transfer of heat from the head to the intake and incoming air giving you up to 5% more power." http://www.hondata.com/heatshieldgasket.html Their statements are not false...and I will have the dyno graphs to back them up. |
"Hondata have developed a special high temperature insulating gasket which replaces the stock intake gasket. This and bypassing several heat sources significantly reduces the transfer of heat from the head to the intake and incoming air giving you up to 5% more power." http://www.hondata.com/heatshieldgasket.html Their statements are not false...and I will have the dyno graphs to back them up. I never trust manufacturer claims and the dyno "proof" they provide, so I'm interested to see how your test plays out. Good luck. :) |
Originally Posted by shivers,Feb 3 2006, 02:47 PM
Unless you dyno your car on the same day, same dyno, with the same IAT temps, same water temps, etc. ... pre and post gasket, the results won't mean much. If possible, you should install the gasket while the car is still on the dyno to eliminate any differences due to strap down tension, tire/roller position, etc.
I never trust manufacturer claims and the dyno "proof" they provide, so I'm interested to see how your test plays out. Good luck. :) The IMG was installed yesterday or the day before. Intake temperatures were measured before and after the install. I don't have any data concerning the temperatures drop yet, but it was confirmed today that my S made an additional 6whp with the IMG. Dyno graphs and intake measurements will be provided to me next Saturday when I pick up the car. Like mentioned before, I use the same dyno every time. Also, the outside temperatures, comparing this last week to four weeks ago, would be very similiar. And, the car would be allowed to idle until the engine temperature is nearly identical. There is nothing deceiving here. The numbers speak for themselves. :thumbup: |
Originally Posted by 2QYK4U,Feb 3 2006, 03:21 PM
Ummm...going to disagree with you. There are some hp/tq gains that are achieved by the reduction in intake temperatures. I don't have the exact figures yet, because testing is still going on, but initial results have proven 5whp gain.
Originally Posted by Elistan,Feb 3 2006, 04:37 PM
No, he's right. Less loss = some gain.
Originally Posted by cdelena,Feb 3 2006, 06:38 PM
Yeah, it's a matter of semantics.. not a power booster but stops some loss from heat. Makes a difference under some conditions, little or none in others.
Are you doubting what I am stating above? |
cdelena is right on and knows what he is talking about. You dont gain horsepower, you just dont loose as much to higher temps. And this mod wont really shows it's self until the summer time or track days. It's like the same thing as all my cooling mods in my sig, they dont gain horsepower, trust me. |
