Hood Dampers
Old Jan 3, 2006 | 01:03 PM
RXDI's Avatar
Default Hood Dampers
I just ordered a set of NRG Hood Dampers for my S.
http://www.getnrg.com/nrghooddamper_kit.php
Do I keep the stock hood prop arm in place? or do I remove it?
I know it doesn't interfere, but I thought maybe since it wasn't needed anymore, I could take it out.
What has everyone else done?
Old Jan 3, 2006 | 01:08 PM
S2kracka's Avatar
You can take it out.
Old Jan 3, 2006 | 01:40 PM
Mad_Paradox's Avatar
i took mines out
Old Jan 3, 2006 | 01:43 PM
RXDI's Avatar
Great, thanks guys.
Old Jan 3, 2006 | 03:48 PM
Billman250's Avatar
Active Streak: 30 Days
Active Streak: 120 Days
Top Answer: 1
I've come accross two types of hood dampers in my days.
The Tein's suck. The hood only opens about 45 degrees.
A guy here by the name of Milkbubble has an awesome set, they put the hood almost straight up.
Old Jan 3, 2006 | 04:06 PM
jimmij's Avatar
NRGs put the hood all the way up. Almost too far. I left the hood prop in just in case.
Old Jan 3, 2006 | 05:30 PM
Emil St-Hilaire's Avatar
I removed it.!!!
Old Jan 3, 2006 | 07:23 PM
milkbubble's Avatar
NRG
Old Jan 4, 2006 | 09:43 AM
Bill,45 degrees is more than enough for me!!!
Old Jan 4, 2006 | 10:30 AM
Cyclon36's Avatar
I like the height of the Teins the best. Exactly the same level as the hood prop actually. Makes it look nice for shows as well. The NRG's are more powerfull though. You feel like the hood is going to fly away when you let go.
Anyway, to the question. I took my hood prop out and shelved it. I doubt you'll need it unless you're doing work on the dampers or need the hood to go straight up.
