hooking up a TACH
There is some info and pictures on my web site here . The BLUE wire in step 2 is the one you want. If it's more convenient, it's also available at the ECM, on connector A, terminal 19, again a BLUE wire.
Originally posted by Kwando
why do you want an aftermarket tach...
to each his own. Have you replace the gauge cluster with something else or are you leaving it the same just a analog tach? There are different clusters avalible... although the more I think about it they are digi display to so I guess your doing this custom then..
Are you going to install it in the gauge cluster space? Because that would look killer
