Hose/Plug Identification
Old Jan 5, 2017 | 06:16 PM
mongomery1234's Avatar
Default Hose/Plug Identification
So I'm finishing up a swap and I have 2 left over cut hoses that I'm not sure where they go. Assuming they definitely don't go together but I could be wrong. Both are located on the right side of the engine (facing the car) one is towards the back and one towards the front near the alternator Tried to get the best pictures possible. The circled red areas are where the hose originates and where it comes to.
Attached Thumbnails Hose/Plug Identification-20170105_211011.jpg   Hose/Plug Identification-20170105_200045.jpg
Old Jan 7, 2017 | 02:40 PM
Up
Old Jan 7, 2017 | 03:19 PM
Spartarus's Avatar
The horizontal fitting that you pictured, at the front of the engine, next the the thermostat housing and paralell to the radiator hose, is the return from the heater core. It goes to the heater bypass hard line and connects to the top fitting on the firewall heater core fitting.
The bent fitting circled in red at the back of the engine, at the block outlet, under the intake manifold, connects the other heater hose, the upper heater tube behind the engine, and the loop with the heater valve.
If you aren't running a heater, you can hook them together.
Old Jan 7, 2017 | 03:33 PM
That's exactly what i was leaning towards as those lines are the only thing not currently on the car. Not running a heater so i can block those off or do i need to connect them together? Also any idea on the plug that's near the thermostat housing? I can't seem to find anything that it would go to.
Old Jan 7, 2017 | 09:55 PM
Spartarus's Avatar
Loop them, don't cap them, the caps will blow off.
The mystery plug is the A/C compressor clutch connector.
Old Jan 8, 2017 | 09:34 AM
Great that makes sense considering the compressor was deleted. Appreciate all of the help.
Old Jun 14, 2020 | 07:50 PM
integfoo's Avatar
Sorry to bring this back but do you know where to get the hose to loop these together? I am in the same spot right now and dont know what the hose is called. Thanks!
Vtechead
Car Talk - Non S2000
Jun 21, 2013 04:19 PM
Mad Mart
Nov 17, 2011 03:14 AM
AeroS2000
Dec 15, 2008 04:54 PM
pputkowski
Oct 20, 2008 11:31 AM
AnthonyShafer
Jun 10, 2002 02:11 PM
