How to disable the AirBag light.
You can remove the bulb from the cluster, and never see the light again. Some steering hubs come with a resistor to simulate a functioning airbag. I couldn't tell you which ones.
since you are not using the airbags, remove the control unit as well. If you are in a accident, the internal impact sensors will still go off and the unit will be junk.
zakazak
Mar 31, 2014 04:58 AM
