How do I separate the tranny from engine?
I am in the middle of replacing my clutch and I can't get the transmission away from the engine. I have tried a little prying & pulling but I can't get the top to pull away. I have removed every bolt as stated in the manual. Any help would be great.
I think I remember a thread like this before. The guy/gal doing the work had left a bolt in that sits near the starter or maybe it was a starter bolt. Once the bolt was taken out it came apart with ease.
I took out the:
starter bolt out
3 upper bolts from trans ---> Engine
2 lower bolts from trans ----> engine
3 Lower bolts from engine ---> trans
I am stumped. How did you go about separating them?
starter bolt out
I have yet to replace my clutch on the S, only have 36k. My 240sx was a pain until I realized I had missed a bolt then it slid off with a prybar. Same with a focus I did, there was a bolt that I missed, once it was out the tranny slip off. I am not sure how many bolts there are to disassemble. I am searching for a DIY but cant find it.
no pictures just a quick run through written out.
Originally Posted by NVMY4N,Sep 29 2007, 12:09 PM
the DIY is linked above in my post, it was in the FAQ/DIY section.
