How hard is it to install DEFI BF gauges?
Old Feb 9, 2006 | 01:25 PM
C45P312's Avatar
Default How hard is it to install DEFI BF gauges?
Thanks guys. Pics or even a write would help. Did a search and came up with no write up but with pictures of installs from like 2003.
-Carlo
Old Feb 9, 2006 | 01:46 PM
Erick S's Avatar
Subscribing...
Erick
Old Feb 11, 2006 | 09:05 PM
C45P312's Avatar
Old Feb 11, 2006 | 11:10 PM
kane.s2k's Avatar
It's really really simple. It's only 4 wires to actually wire. Light source, 12v+ ignition, 12v+ power, ground.
Under the dash is a fuse box that has places that you can connect some male connects into (no shielding). If you look, you'll probably see it. It has a light 12v+, 12v+ignition, 12v+ always on, and then just connect the ground.
I'll try and search around for a picture of what I'm talking about.
The sensors are just regular sensors you put on. They are just like any other gauges. The whole process is really simple.
You daisy chain the gauges together. (You will see a total of 3 connectors on the back of the gauge. One of them has 2 together and another all the way on the top). You connect one wire to the pair, then one out to the next gauge.
controller--> gauge1--> gauge2--> gauge3....etc
Old Feb 11, 2006 | 11:13 PM
kane.s2k's Avatar
https://www.s2ki.com/forums/index.php?showt...l=gauge++sender
https://www.s2ki.com/forums/index.php?showtopic=99530
Old Feb 12, 2006 | 09:09 PM
FF2Skip's Avatar
Carlo, why do you need exhaust gas temps?
Old Feb 12, 2006 | 10:14 PM
DJFriar's Avatar
I'm looking at adding some of those as well, what gauges would be the best to add?
Also, where's a good place to get the A-Pillar Gauge Pods?
Old Feb 13, 2006 | 09:16 AM
C45P312's Avatar
Because DEFI doesnt make A/F gauges in BF Imperials.
DJFriar: I would look at Science of Speed for thier a-pillar pod
Old Feb 13, 2006 | 09:22 AM
C45P312's Avatar
Thanks bro.
Old Feb 13, 2006 | 09:23 AM
FF2Skip's Avatar
So EGT is a good estimate of A/F ratios?
