how to make our engine revs faster???
Old Aug 7, 2003 | 04:01 PM
S2000_Europe's Avatar
Default how to make our engine revs faster???
The only way that I know is with a lighter flywheel.... any other way?
Old Aug 7, 2003 | 04:19 PM
Sideways's Avatar
Lighten up any of the spinning mass such as the pullies. https://www.s2ki.com/forums/showthread.php?...threadid=141549
Old Aug 7, 2003 | 06:39 PM
xviper's Avatar
You can lighten stuff all you like. It's not going to spin any faster safely unless you address the issue of valve float. Oh, and you gotta change the rev limiter.
Old Aug 7, 2003 | 07:20 PM
JL9000's Avatar
[QUOTE]Originally posted by xviper
[B]You can lighten stuff all you like.
Old Aug 7, 2003 | 07:34 PM
slick rick's Avatar
Higher vs. Faster
Rev up quicker?
Old Aug 7, 2003 | 07:54 PM
slalom44's Avatar
Top Answer: 1
I think JL9000 may be right. I suspect that S2000_Europe may have chosen different words than we commonly use. Instead of asking "how to make our engine revs faster?", he should have asked, "how can we increase acceleration?"
The obvious answers are to reduce rotational mass (as previously mentioned), reduce vehicle weight, increase torque (literally dozens of ways), minimize friction in moving parts, reduce wind resistance, and shift higher in the torque curve.
Most techniques for increasing acceleration fit in one of these categories, although I probably missed a few.
Old Aug 7, 2003 | 08:07 PM
xviper's Avatar
Well, geez! Never mind then!
Old Aug 7, 2003 | 09:51 PM
Originally posted by JL9000
I think he was asking how you can make the engine rev up faster, not hot to make it literally rev faster.
Yes that is what I want to say, some time I translate to English literately form Spanish
Old Aug 8, 2003 | 07:17 AM
TepEvan's Avatar
Old Aug 8, 2003 | 07:23 AM
Gernby's Avatar
Former Sponsor
Originally posted by TepEvan
Is this why unorthodox doesn't make smaller pulleys for the S?
Xviper was addressing a different question. AFAIK, nobody makes underdrive crank pulleys because they aren't good for the crank bearings, and there is a small market. There is probably also less to be gained from them since we have electronic power steering. I would like to see an oversized water pump pulley...
