How to remove fenders
Here's the DIY:
(All bolts 10mm)
1. Remove front bumper (whole other DIY)
2. Remove 2 fender bolts from side of headlight mounting plate
5. Remove 3 outer fender liner plastic clips
6. Remove 2 fender liner screws (in rear)
3. Remove 5 fender bolts in engine bay
4. Remove 3 fender bolts from under the car
5. Remove 1 bolt behind the upper door fender with wrench (you'll see these with door open)
6. Remove 1 bolt behind the lower door fender with long socket extension
7. Pull the whole fender carefully to not scratch the car (sharp edges!) and untwist side marker bulb fitting from inside
</corona>
(All bolts 10mm)
</corona>
