HOW TO: Replace the S2000 TCT (Timing Chain Tensioner)
Old Oct 8, 2017 | 05:48 PM
Snowmants's Avatar
Default HOW TO: Replace the S2000 TCT (Timing Chain Tensioner)
I put together a "How To" video for replacing the S2000 Timing Chain Tensioner (TCT), for those interested in what is involved. I hope this is helpful!
Old Oct 9, 2017 | 12:23 PM
hirev's Avatar
thanks, well done, you showed it as an easy fix nicely.
Old Oct 10, 2017 | 10:45 AM
Snowmants's Avatar
Thanks!
Old Jun 28, 2020 | 10:23 PM
ioeric's Avatar
Thanks!
Old Jun 29, 2020 | 03:54 AM
randomwalk101's Avatar
Awesome. Thanks for posting.
Old Jun 29, 2020 | 05:24 AM
02civicsi's Avatar
Did you not pull the pin for the piston, looks like the pin is still installed on the new Billman TCT. Am I incorrect at 6:30 of the video?
Old Jun 29, 2020 | 06:14 AM
Billman250's Avatar
Active Streak: 30 Days
Active Streak: 120 Days
Top Answer: 1
Video is correct, the pin is installed.
It does not get removed until the tensioner is bolted in place (same as oem)
Old Jun 29, 2020 | 06:48 AM
02civicsi's Avatar
Thank you for clarifying; the pin is removed through the bolt hole?
Old Jun 29, 2020 | 07:58 AM
Billman250's Avatar
Top Answer: 1
Yes, he removes the pin in the video.
Old Jun 29, 2020 | 09:30 AM
Chuck S's Avatar
Did you watch all the way to the end of the video? (Hint: past minute 9.)
-- Chuck
65corvette1
Sep 23, 2013 11:26 AM
macr88
Engine
Jan 28, 2010 12:25 AM
hkspwrsche
Mar 17, 2006 06:40 AM
