@etang789 doesn't reset after battery disconnection
Hi i'm new here I want to fix my Problem I read how to do the reset. The problem is if the trouble code comes if I turn the steering to 45 degrees the EPS doesn't comes on for 4 sec :S And on my model i need to take the Connector under steering wheel one like this https://i133.photobucket.com/albums/...sodds/SCS3.jpg |
Originally Posted by XDCs2k
(Post 22971194)
Had to make an emergency trip to the corner store in my S in 15 degree weather while I was replacing the RSX clutch. I lost all power steering temporarily. After letting it warm up completely, I took a 5 minute ride to the store with absolutely no steering assist, EPS light was on. After going into the store, I start the car and the wheel turns by itself all the way to the left lock. The EPS light was no longer on and I had full left-hand assist and choppy right hand assist. Weird
Fast forward two weeks and my buddy lets me use his snapon ethos to ground the SCS to reset neutral position. I did the reset procedure and now have full, equal assist in all steering positions. They key is to keep continuous torque input on the wheel when turning left to the 45 degree position. Despite what billman said in one of his more recent EPS posts, I took my hand off the wheel in the straight ahead position per the FSM. Everything has been working great! |
Bringing this back up.. I'm having trouble with step 4. My eps light doesn't stay on instead the abs/srs/eps light keeps blinking.. help? Am I not initiating it right?
Additional info: steering wheel turns right until lock. Alignment is straight wheels are straight tire pressure is fine. I have a 00 and just swapped in a used eps module from 02. Srs light is on because I have aftermarket steering wheel setup. If I start the car the only light I have is my srs, nothing else. Edit: I just pulled the codes. Abs code is 61 and eps code is 23. What do I do now? Billman please shed some light! |
Bump...
:hello:
Originally Posted by SoREALemjay
(Post 23594346)
I'm having the same issues with the eps going out, I can't used the obd2 port to access any codes because I have a aem infinity installed, I tried the battery removal but eps is still out. i will try the reset procedure and chime in to whether i got it to work or not.
Originally Posted by deuce_s2k
(Post 23803917)
Hello I am having the same issue with my power steering being out as well as still not owning my stock ecu. Is it possible to buy another OEM ecu and then perform the torque sensor with the procedure outlined above? Thanks!
