how to switch thremostat and thermo switch????
Old Dec 17, 2002 | 07:05 PM
BlueS2000Boy's Avatar
Default how to switch thremostat and thermo switch????
i'm getting the spoon sports thermostat and thermostat switch. can anyone help me on how to change them out?
Old Dec 18, 2002 | 05:37 AM
smccurry's Avatar
You're going to need to get under the car for these installs, so you'll need access to either a lift, or a jack and jack stands.
You'll need to drain the coolant first.
The fan switch is a breeze. You just need to get a 22mm wrench if my memory serves me right.
The thermostat was a bitch to get to. Some say they didn't need a special wrench, but I couldn't get a regular socket set to fit in the tight space you have to navigate. Others have recommended either a wobble wrench or extensions to get to the two 10mm bolts you'll need to remove to take off the thermostat.
If you've never refilled coolant before, don't forget to get the combination rad cap/funnel tool or you'll have coolant overflowing everywhere. Also don't forget to open the coolant bleed bolt (also 10mm) right below the intake manifold towards the front of the engine until you've bled the air out of the system.
For someone who has done this before, it would probably take about 30 minutes. For a first-timer, I would think you would need several hours (for a novice, like I am).
Good luck.
Old Dec 18, 2002 | 06:17 AM
Gernby's Avatar
Former Sponsor
Huh? I didn't have a problem with this. I just used a funnel.
Unless you intend on doing a complete flush, you should get the same coolant that is in it now. If you have an '02, you will need the Honda Type II coolant that is already mixed 50/50. You will need 2 gallons of this, and you won't have to add distilled water to it.
Old Dec 18, 2002 | 07:08 PM
smccurry's Avatar
[QUOTE]Originally posted by gernby
[B]
Huh?
Old Dec 18, 2002 | 07:12 PM
funsdead's Avatar
i'm a noob....what r the advantages of the spoon or mugen thermostat and the fan switch. Does it just engage the fan at a lower temp?
Old Dec 18, 2002 | 11:12 PM
well i havn't got them yet i will be ordering them today so i should have them in a couple of days. the fan switch is the one in the front of the engine right. its plan in the light to see right? i have done my coolent before so i should i have prob with this. but i eill let you guys know how it goes. i'm still not quite sure where the thermostat is. if someone could give me a little more detail as to where i is that would help a lot. i have switched a thermo already onmy friends car just now an s2000.
Mad Mart
Nov 17, 2011 03:14 AM
stu_c
Nov 22, 2009 03:07 AM
s2k54
Oct 28, 2007 11:46 AM
whiteGoKart39
Feb 13, 2003 09:56 PM
