how to tell difference between ap1/ap2 diff
Old Feb 9, 2008 | 09:49 AM
nrgizeman's Avatar
Default how to tell difference between ap1/ap2 diff
just received my 4.56 installed diff from hardtopguy. other than opening the case to check what diff it is, how can you tell just by looking at its outer body? i have ap2 and asked for ap2 diff housing.
Old Feb 9, 2008 | 10:21 AM
Stratocaster's Avatar
No there is no way to tell from the outside. So if you are conserned that HTG is being dishonest, I would advise you jut to return it to you and be done with it.
Old Feb 9, 2008 | 02:37 PM
goldenfri's Avatar
The bolts used to connect the diff to the drive shaft are bigger on the AP2 Diff. Hardtopguy is
Old Feb 9, 2008 | 02:42 PM
Billman250's Avatar
Active Streak: 30 Days
Active Streak: 120 Days
Top Answer: 1
Don't look at the housing, look at the shipping label.
Because you got it from Hardtopguy, that's how.
Old Feb 9, 2008 | 03:55 PM
S2KPUDDYDAD's Avatar
As to the tech question,
There is no way to tell from the outside other than the pinion flange having larger holes in it for the 10 mm screws.
You would have to open it up to look at the bearing caps, that is the only way to tell.
If you bought it from Jeff then it is what he said it is AP2
Old Feb 10, 2008 | 12:02 AM
nrgizeman's Avatar
hehehe... just a question for future reference... not to question hardtopguys honesty.
s2kq8
May 20, 2016 01:43 PM
jpark
Feb 22, 2013 01:15 PM
cloud_9
Apr 5, 2008 05:40 PM
CHOWBOX
May 9, 2007 06:34 PM
