how to tighten the throttle cable
i looked at my today n the throttle cable was loose how do i tighten it back up :confused:
https://www.s2ki.com/forums/index.php?showt...0&#entry2334594
i've been meaning to do this too, just been lazy and no tools :( |
I just put in a new TB and now I am not sure what idle RPM should be on MY01. Anyone know?
varies between 900-1100 depending on ____ insert condition here.
Have the cable on loose with the car running. Tell a friend to sit in the car and tighten until the rpms start to rise a bit and then loosen a little bit. Voila
Originally Posted by floridawriter,May 17 2007, 11:24 AM
That is not the correct method for adjusting the throttle cable.
Leave ~1/4 inch vertical play. This comes straight from Honda. Learn it, live it.
it said free play. my method was to tug it back and forth and measure the "free play"...after all...the pedal pulls on the cable...so i interpret free play to be back and forth in the line that the cable travels... i see no reason why vertical movement has anything to do with the free play. |
