how to tighten the throttle cable
Old May 15, 2007 | 01:15 AM
Qs2k's Avatar
Default how to tighten the throttle cable
i looked at my today n the throttle cable was loose how do i tighten it back up
Old May 15, 2007 | 01:25 AM
tekstar's Avatar
https://www.s2ki.com/forums/index.php?showt...0&#entry2334594
i've been meaning to do this too, just been lazy and no tools
Old May 16, 2007 | 05:50 PM
JimmyB's Avatar
I just put in a new TB and now I am not sure what idle RPM should be on MY01. Anyone know?
Old May 17, 2007 | 05:41 AM
vtec9's Avatar
varies between 900-1100 depending on ____ insert condition here.
Old May 17, 2007 | 06:19 AM
tinkfist's Avatar
Old May 17, 2007 | 07:24 AM
TrackStar's Avatar
Have the cable on loose with the car running. Tell a friend to sit in the car and tighten until the rpms start to rise a bit and then loosen a little bit. Voila
Old May 17, 2007 | 08:24 AM
floridawriter's Avatar
That is not the correct method for adjusting the throttle cable.
Old May 17, 2007 | 10:42 AM
TrackStar's Avatar
It works though. Can you post the correct version for us?
Old May 17, 2007 | 10:53 AM
vtec9's Avatar
Leave ~1/4 inch vertical play. This comes straight from Honda. Learn it, live it.
Old May 17, 2007 | 10:59 AM
jyeung528's Avatar
it never said "vertical play"
it said free play.
my method was to tug it back and forth and measure the "free play"...after all...the pedal pulls on the cable...so i interpret free play to be back and forth in the line that the cable travels...
i see no reason why vertical movement has anything to do with the free play.
