How Would U Make The S2000 Handle More Boost?
Old Mar 3, 2003 | 02:04 AM
s2korevoVIII's Avatar
Default How Would U Make The S2000 Handle More Boost?
if i only put in custom je pistons (8.1compression ratio) how much boost could i crank up, and if this is not enough what else do i need besides the usual i need an indepth kind of explination, i need 16 psi of boost which = about 400 hp
Old Mar 3, 2003 | 06:26 AM
MacGyver's Avatar
It all depends on how long you're willing to let the engine last.
Moderators...isn't it about time to remove this guy since he can only seem to ask stupid "What if..." questions?
Old Mar 3, 2003 | 07:06 AM
HwangTKD's Avatar
I AGREE!!!!
s2korevoVIII,
STOP POSTING AND USE THE SEARCH!!!
Old Mar 3, 2003 | 07:12 AM
infinitebass's Avatar
Banned
I think he might just be a troll...
Blake
Old Mar 3, 2003 | 07:15 AM
xpander4's Avatar
thicker head gasket, lower the compression.
Old Mar 3, 2003 | 07:44 AM
S2000_Europe's Avatar
Come on dont blame on him he has only 14 days old!!!
I think the problem of asking always the same question is ask to some morerator to include some closed thread into S2ki library.
Currently that section has nothing in it
Old Mar 3, 2003 | 09:13 AM
Randman's Avatar
Why do you need 16 lbs of boost? You dont have the car to begin with, and it's not like you ever will. Stop asking stupid questions, go bug people on an Evo forum.
Old Mar 3, 2003 | 12:10 PM
sfphinkterMC's Avatar
darton sleeves
Old Mar 3, 2003 | 12:50 PM
VTEC Racer's Avatar
Is resleeving the block for the F20C always required when upgrading pistons? Are there any type of pistons out there that can be used that will be compatible with the stock sleeves? If not, what type WOULD we need?
Old Mar 3, 2003 | 02:53 PM
God's Avatar
God
2 liters/8:1/16 psi
Does not equal 400 hp.
If you lowered the compression that much... I doubt you would get much more power than stock (perhaps a little?)
(WRX is a two liter with 8:1 compression and it runs about 14 psi stock)
