id-ing a bolt
Old Nov 24, 2004 | 11:56 PM
mikecl713's Avatar
Default id-ing a bolt
i took off my comptech sc kit... i need to buy the big bolt next to the vtec solenoid.... its the one with the washer used to bolt on the black block where one point of the sc bolts onto.... I cant find the original bolt that goes in that hole.....
nor i can find the replacement on the hondaautomotiveparts diagrams..
Old Nov 25, 2004 | 06:23 AM
xviper's Avatar
Mike, if I'm thinking what you're thinking, I believe there never was a bolt in that hole. This is the hole that you can bolt some kind of hook or bracket so that the engine can be lifted out of the car. You will find another similar hole at the other end of the engine. There is no bolt there either.
Comptech just used this as a secure point of attachment.
Old Nov 25, 2004 | 07:09 AM
Slows2k's Avatar
The VTEC solenoid is held on by 3 6x1mm bolts, with a 10mm head. The rear bolt hole is unused. It's a attachment point for a lift bracket when removing the engine from the car.
Old Nov 25, 2004 | 12:33 PM
Billman250's Avatar
Active Streak: 30 Days
Active Streak: 120 Days
Top Answer: 1
This is a gray area...Two VORTECH's I've worked on utilize this hole with a nice beefy bolt, the other's don't. For my money, I'd use the hole. I can post the exact/size length if you guys wanna add it. As far as your COMPTECH.....I'll let you know if my two customers use it or not. The length is critical, as you'll crack the head if it's too long...I know Comptech upgraded their bracketry at some point.
Old Nov 25, 2004 | 01:13 PM
xviper's Avatar
Billman, I'm not so sure it's really a "grey" area. If you go to the link below and look at page 21, figures 7-V and 7-W, you'll see that Vortech stipulates the use of this attachment point. They even provide the bolt.
http://www.vortechsuperchargers.com/...s/4hs218im.pdf
Those that you saw that did not use this bolt, I can only
Old Nov 25, 2004 | 04:58 PM
Slows2k's Avatar
Every Vortech I've seen has used a bolt in that location. I'm with Xviper, they should be using a bolt in that location.
The Comptech brackets I've seen use rubber isolators on the main SC plate. The brackets on the head and alternator are not isolated.
Old Nov 25, 2004 | 06:06 PM
Billman250's Avatar
Top Answer: 1
Agreed Think the bolt can be added to the Comptech unit? One of my Comptech customers hit a pothole and snapped that bracket clean in half. Wonder if that bolt would have helped...
Old Nov 26, 2004 | 06:08 AM
xviper's Avatar
According to the Comptech installation manual:
http://www.comptechusa.com/instructions/ins072.pdf
At the top of page 4, it would appear as though the kit comes with that big bolt and the bracket has a hole for the bolt to go through and into the engine. If those cars you see don't have this bolt, it's probably because it was either missing, lost or was never put on.
Old Nov 26, 2004 | 08:24 AM
Billman250's Avatar
Top Answer: 1
Xv
Old Nov 26, 2004 | 08:29 AM
SM00TH976's Avatar
just for future reference, if you ever need to know the size and thread pitch of a bolt, home depot and lowes have bolt holes that allow you to screw in your bolt to see what the exact size it is. this probably wouldn't work for a scenario like this though because you don't physically have the bolt. just figured i'd throw it out there since it's helped me before.
