Idle Problems
Old Jul 28, 2006 | 05:52 AM
s2kpr01's Avatar
Thumbs up Idle Problems
Hi
Recently ive been encountering some issues with my S2k,it has a weird Idle, sometimes at a stop-light the idle rpm's drop below 1K and the engine begins to struggle , I give it some gas and its fine.
I thought it could be the IACV (Idle Control Valve) , I bought a brand new IACV and replaced it, but it didnt help at all.
BTW , its worse when i turn the A/C On
Any suggestions ?
Thanks
Old Jul 28, 2006 | 06:10 AM
S2KXTACY's Avatar
Does the car have a rough idle period or only at stop signs? Do you drive your car hard? Under the hood does it have any weird noises like something broken?
Old Jul 28, 2006 | 06:52 AM
vtec9's Avatar
https://www.s2ki.com/forums/index.php?showtopic=386868
Old Jul 28, 2006 | 07:27 AM
xviper's Avatar
If you keep doing this, it will simply continue to do this until the weather changes. It needs to nearly die for it to learn. "Helping" it only prolongs the learning process and you will take that much longer to get this issue out of the way.
Old Jul 28, 2006 | 08:47 AM
floridawriter's Avatar
Avoid stop signs
Old Jul 28, 2006 | 08:59 AM
Jasonoff's Avatar
Banned
Old Jul 28, 2006 | 10:06 AM
xviper's Avatar
Originally Posted by floridawriter,Jul 28 2006, 10:47 AM
Avoid stop signs
Or coasting a long ways with clutch pushed down while approaching the stop. This confuses the heck out of the ECU.
Old Jul 31, 2006 | 01:37 PM
Just Guy's Avatar
[QUOTE=s2kpr01,Jul 28 2006, 05:52 AM]Hi
Old Aug 1, 2006 | 08:18 AM
David1's Avatar
This has been more evident on mine since it has been really hot 90+ out. A couple of days and the ECU still has a tough time when the AC compressor comes back on along with the heat soak.
Old Aug 3, 2006 | 08:31 PM
Defender's Avatar
Have you had any work done on your wiring harness ? Has it been removed and reinstalled ?
