Idle Problems
I have Idle problems when ever i come to a stop sign and the car sometimes dies. I was wondering what can be the result of having idle problems? o2sensor, vacum leak, or what?
Couple of things to consider:
Map sensor whack might be needed. Possible change in weather heat/cold. Adjust throttle cable. Tim |
maybe something in your gas?
from reading the other threads recently... maybe you bent a valve?
Do not adjust the throttle cabel that is the job of the IAC.
Your IAC needs to be cleaned first off. I am willing to bet it is really dirty and causing your rough idle. If need be I will explain the process. |
Just do an ECU reset and go though the idle learn procedure see if that helps.
Sniper. |
If it also idles rough and you have erratic off-idle acceleration - map whack. Otherwise, I'd lean towards the IAC.
I think it might be important to ask whether or not you have any mods on the car.
Are you using anything other than the OEM intake system? |
What is IAC? And how can i fix that?
