ignition help
Old Feb 17, 2012 | 12:44 PM
estooki's Avatar
Default ignition help
my tumblers in the ignition broke (key wouldnt turn anymore) so i picked up a ignition lock cylinder with matching key from a parted s2000.
i swapped the ignition, the car would crank but would not turn over
Is this something that has to do with the immobilizer?
would i need to get this reprogrammed?
any help would be great
thanks
Old Feb 17, 2012 | 01:24 PM
emdzey01's Avatar
Yes, you'll need your ECU reprogrammed at the dealer to accept the new key that's equipped with an immobilizer.
Check with your local honda dealer for the cost.
Old Feb 17, 2012 | 08:02 PM
Noodler's Avatar
try holding the old key next to the new key and see if it will run then
Old Feb 17, 2012 | 08:54 PM
estooki's Avatar
Yah figured it would be needed to be programmed.
Tried holding the old key next to be but still wouldnt turn over
Blacknot
Oct 23, 2009 03:57 PM
Silvers808
Feb 28, 2007 01:10 PM
JToolz
Nov 13, 2006 02:33 PM
steven975
May 15, 2004 09:20 AM
Snowboarder714
Jan 21, 2003 08:21 AM
