I just received my kn fipk intake system, I go and attempt to install the intake. Everything was going smoothly until it came to taking the original tubing/hose off of the car, it is literally IMPOSSIBLE to remove any of the tubing, be it from the air injection pump hose, crank case vent hose, or any other sort of hose or tube. Yes, I removed the metal claps, and pulled as hard as I could from all different angles.
It feels like someone super glued them together, does anyone have any idea what's going on?
Instructions for install... I'm thinking the tubes should be a breeze to take off, but they are impossible.
You need to try to pull and twist back and forth to get them free the first time. They can be a pain. If you have a pair of vice grips, you can squeeze the larger hoses and use the pliers to gain leverage in twisting the hose.
Yeah that was definitely a pain. I took a really thin flat head and just stuck it in and pulled it off. Good luck with the install though. Once you put it in the sound is definitely nice. I've gotten nothing but compliments from mine.
nice.. i been looking to buy some more tools since its been a while since i got any specialty stuff. and thats what i usually buy from now on since i have all your standard stuff
I never had any problems when using silicon spray. Just need to pry a portion of the hose off to stick the plastic tube and spray. Let it sit for few minutes and pull it off.
