Inaccurate Gas Guage (Billman plz help)
I have a 04 S2000 with an annoying problem. As my car has aged, the gas gauge has become increasingly inaccurate. It used to be fairly accurate ie., the gas light would come on when I was nearly dead empty. Now, the gauge is completely worthless. For example, last week my gauge indicated I was dead empty (no bars left, gas light consistently on). When I went to fill it up, the car only took 10.3 gallons! Does anyone know if there is a way to make the gas gauge more accurate?
-Will
-Will
Originally Posted by turbolane,Apr 23 2007, 03:10 PM
I had a similar problem, which the Honda dealer diagnosed as an issue covered under warranty (I forget the exact cause, some part was either not sending or reading the measurement correctly).
If you're still covered under the factory warranty, the dealer has to prove the mod caused the failure. If you have a fuel pressure regulator, then maybe they might refuse...if you have an AEM EMS, they certainly would refuse. If you have a supercharger and suspension mods, they have to show how that would cause the problem.
If you have the extended warranty and are modded, you need to cancel the policy and get a refund for the unused portion.
Originally Posted by rugsr,Apr 23 2007, 11:29 AM
I heard its bad to bring it to E and fill up to F...wait till 1/2 so the crap in the bottom of the tank doesnt get sucked up...
Thats what i hear...thats what i do.
But yea that is annoying
