Inexpensive exhaust modification
Old Sep 4, 2001 | 10:36 PM
WRS2K's Avatar
Default Inexpensive exhaust modification
Seeing how dual exhausts don't add any performance to the S2000, I was just thinking about doing a really inexpensive exhaust mod.
Here's a link to one of the suggested ways of going about modding my stock exhaust:
https://www.s2ki.com/forums/showthread.php?...&threadid=27077
Will this affect performance in a negative way? Do you guys recommend this? All I want is a louder, deeper sound and if it doesn't do anything for gains, I'm fine with that as long as it doesn't take away.
Thanks.
Old Dec 24, 2004 | 07:32 PM
SoCalIsMyLife's Avatar
Brought a post back to life!!! wow, september 2001
Old Dec 25, 2004 | 04:25 AM
hygiene boy's Avatar
My brother did that years ago on his S2K and it sounds better than any exhaust I've ever heard. He only replaced his mufflers with black Hayame cannisters, the rest of the OEM piping stayed intact. He dynoed and gained one torque
Old Dec 25, 2004 | 06:19 AM
WPS's Avatar
WPS
there even another more inexpensive one. someone here just cut off the mufflers, resonator, y pipe to exhaust tip. there's still a resonator so its not too loud but makes the stock louder and lighter by getting rid of the heavy canisters. forget who did it
Old Dec 26, 2004 | 08:14 AM
ttvolvo's Avatar
Does anyone try just remove the resonater and with stock muffler .What does it sound like?Any hp gain or loss?
Old Dec 26, 2004 | 08:16 AM
Chitah831's Avatar
Many people removed just the resonators. Supposed to sound real nice. Not sure of any gains though.
Old Dec 26, 2004 | 08:35 AM
ttvolvo's Avatar
I may give it a try just remove the resoniater.So far I can't found a better exhuast system is better looking than my stock 04 exhaust tip.Does any o4-05 ower install a aftermaket system and able keep the stock tips with car?
Old Dec 26, 2004 | 08:40 AM
Chitah831's Avatar
If you go with a custom setup then you should be able to put your stock 04 tips onto the ends of the new mufflers.
You should also check out Spugen exhausts as they have oval tips, and also Supersprint has oval tips.
Old Dec 27, 2004 | 08:51 AM
Cubs2k's Avatar
Earlier this month I had a exhuast shop install 2 Magnaflow 14814 mufflers to most of my OEM exhaust system.
The factory system was cut right before the Y and a new Y was made with 2.5 inch stainless to the new mufflers.
Minimal drone and noise, deeper tone. I like it!
Old Dec 27, 2004 | 02:57 PM
tron1's Avatar
FYI
http://forums.s2ki.com/forums/index.php?showtopic=179928
