INFO: Motor/Diff Mounts
Old Feb 10, 2011 | 03:48 AM
Opc's Avatar
Opc
Default INFO: Motor/Diff Mounts
Hey guys, got such a great response, messages and comments on my coilpack info thread i'm making anther tonight. Few things to iron out and add, but this is the start of it so far.
Mounts And Prices
Front engine mounts,
Part number: 50810-S2A-003 Cost: $115 each, 2 needed.
Rear Diff
Part number: 50710-S2A-000 Cost: $28.71 each, 2 needed. Front small
Part number: 50730-S2A-003 Cost: $63.51 large rear. R
Part number: 50740-S2A-003 Cost $63.51 large rear. L
DIY
Filled mounts or even mounts made from scratch can use materials to damper vibrations caused by the drive line and the suspension.
List of aftermarket materials easily obtained from the internet.
3M Window Weld 65A
Devcon Flexane 80 Liquid
Quicksteel 85A
Devcon Flexane 94 Liquid Resin 95A
Solid Epoxy
Aftermarket mount company's
Innovative Mounts 00-08 cost: $320
60a red, 75a black, 85a grey
Megan Racing, Front: $330 Diff Kit: 360
Additional photos
Opc's Avatar
Opc
FIRST !!!..
Old Feb 10, 2011 | 03:54 AM
Billman250's Avatar
Active Streak: 30 Days
Active Streak: 120 Days
Top Answer: 1
I've been finding broken engine mounts on cars that the owner did not know they were broke.
Using a 4 foot bar, I lift on each front corner of the engine by prying over the top shock tower bolts. You can lift the engine up and down about 1.5 inches, and feel/see the broken mounts.
I've seen 4 or more large left leaking dif mounts. Never a large right.
Old Feb 10, 2011 | 04:01 AM
Opc's Avatar
Opc
great advice billman!
Do you happen to know what the fluid is, oil, hydraulic fluid, some generic fluid?
Old Jan 5, 2014 | 11:51 PM
Lunacy's Avatar
I am wondering if the front diff mounts 50710-S2A-000 are oil filled as well?
Old Jan 6, 2014 | 07:44 AM
s2000maniac's Avatar
engine and diff mounts are fluid filled. the trans mounts seem to be solid rubber. here some great prices on motor and trans mount.
http://www.amazon.com/DEA-A4564-Fron...onda+s2000+dea
http://www.amazon.com/DEA-Products-A...onda+s2000+dea
Old May 9, 2014 | 09:51 PM
AZS2KDancer's Avatar
What is involved in changing motor mounts. My dealer's free road inspection says a few are starting to leak.
Old May 10, 2014 | 07:16 AM
I changed my s2k motor mounts around 130-140k miles and both were broken. I would say the easiest way to change them out is to support the engine by the oil pan area and remove the brackets that bolt to the engine along with engine mounts. Reason I say this is because it's kinda hard to get to the top engine mount bolt. With the brackets removed, you won't have that issue.
Old May 10, 2014 | 06:53 PM
I don't know if I have the tools to support the engine. If I take it to a shop for service, what's a reasonable fee?
Old May 10, 2014 | 08:06 PM
Slowcrash_101's Avatar
It's a one hour job for both so they'll charge you whatever their hourly rate is.
