INJEN CAI....can't get it to fit!!!! pls help!
well, i bought a used CAI and i can't seem to get the pipe to go in. could someone please advise me on how to do it, such as do i need to remove anything other than the stock airbox? bumper? fan? please help! i tried to install it, but the shape does not make it easy to navigate it into place. thanks all!!!!
Originally posted by chrts
remove the fan, and you have to cut a liittle bit of the plastic by the wheel. take off the under tray where the injen intake ends up and install the filter from under the car.
chris
chris
) also, which part do i have to cut and is it a plastic piece or something else? should i cut it where it is or take it out first? thanks for all your help! man, i was frustrated and ended up putting everything back!!!
hopefully, i can do it tomorrow if i can!!! thanks!!! anything else that might help??? any pics?? i'd like to see how it's done and what portion is cut...and actually, how much is needed to be cut!!!!
man, i love this forum!!! you guys are a great help!!!
chris
chris
You posted to remove then fan on the AEM install also. Have you ever installed a CAI on the S2000?
Utah
Utah
Utah
Utah
Utah
Originally posted by turbo_pwr
I have to go with Utah on this, why the hell would you need to remove the fan?
Some people try to make work easy is another reason.
well, the fan may get in the way, i was going to do that but i still had some doubts as to whether i could get the CAI to fit. the bottom plastic piece was my real concern, now i hear about cutting something out! ughhh! ok ok, i should relax!
1. do i have to KEEP the plastic under cover off of the right side or can i replace it (enough room?) when i'm done putting the CAI in? if i have to keep it off, should i cut a hole out for it to fit with the under cover or keep it off?
2. what portion do i have to actually cut (not the under cover). anyone have any pics of this area?
AGAIN...thanks all for the support and advise!!!!! i really appreciate it all guys!!!!!!!!
