Injen check engine light came on
Just installed my Injen today... everything went smoothly, however, after I started the car the engine light came on. I did a quick search and went back to check the tubes I'm sure they're all correctly. Here are two pics can someone confirm for me?
The bottom small red line goes to the air sensor and the upper one goes to the one way check valve correct?
here's another shot.
I'm too lazy to go down and try reseting the ECU, I'll try that tomorrow.
I can't see in your pics all of the angles and vantage points but I did a "How To" a little while ago. Go here and just follow my hose routing to see if yours make sense.
https://www.s2ki.com/forums/showthread.php?...148#post1365148
If you got a CEL and then changed the hoses to the correct configuration, the light won't simple go off right away. It takes a few driving cycles for this to happen or you can reset the ECU by pulling the ECU backup fuse.
Thanks guys. I'll try reseting the ECU next tonight, stuck at work right now. I'm sure I got all the hoses. The top one goes directly to the check valve. I did fire her up the first time and forgot to hook up one of the hose, so I think this might have caused the CEL - a reset should fix her all up. I can't wait to take her out for a spin
Originally posted by xviper
Like "9906" indicated, make sure the white check valve is facing in the correct direction.
say don't you guys ever have to work?
