Inspecting Transmission before install
Old Sep 18, 2018 | 06:41 AM
yourboysoap's Avatar
Default Inspecting Transmission before install
I bought an AP2 transmission probably 5 years from a low mileage accident part out. I had every intention of swapping out my AP1 transmission for this one, but money and schedule kept pushing this back and I decided to just beat on the AP1 trans until the clutch or trans failed. At this point, I am close to getting the original trans out but before I put in this AP2 trans I've had sitting, is there any preparation or checks I can do with it outside the car? Maybe attach the shifter and make sure I can get it into gears? Just want to do my due diligence before I get it back in. Thanks!
Old Sep 18, 2018 | 08:13 AM
Billman250's Avatar
Active Streak: 30 Days
Active Streak: 120 Days
Top Answer: 1
If you really want a great test, spin the tailshaft with a drill. Once up to speed, run the shifter through the gears 6-1 and back up.
The trans shafts will be easier to get moving in 6th gear, then go 5-4-3-2-1, Then 2-3-4-5-6.
Old Sep 18, 2018 | 09:08 AM
Car Analogy's Avatar
Good to know!
But, how to attach drill to trans shaft?
Old Sep 18, 2018 | 11:25 AM
Billman250's Avatar
Top Answer: 1
Socket adapter.
Old Sep 18, 2018 | 11:33 AM
freq's Avatar
I've seen Bill use this technique on my trans.
Old Sep 18, 2018 | 01:29 PM
cosmomiller's Avatar
Top Answer: 1
The stuff you can learn on this site!
Old Sep 18, 2018 | 02:03 PM
Chuck S's Avatar
I'm guessing rotation direction is important?
-- Chuck
Old Sep 19, 2018 | 03:09 PM
freq's Avatar
Facebook is WAY better. /s
Old Sep 21, 2018 | 06:14 AM
-- Chuck
Would love an answer on this
Old Sep 21, 2018 | 07:18 AM
flanders's Avatar
Do you run your motors backwards often? Probably not a good idea to spin the transmission backwards either
If you stand in front of engine it should turn clockwise.
