to install 5mm spacers, do i need extended studs?
Old Dec 26, 2007 | 04:33 PM
marlonRocks's Avatar
Default to install 5mm spacers, do i need extended studs?
anyone have a quick answer? thx in advance
Old Dec 26, 2007 | 05:05 PM
124Spider's Avatar
If you have 5mm of stud sticking out the back of your lug nuts, you shouldn't need long studs. If you have less than 5mm of stud sticking out, I wouldn't use the spacers without longer studs.
YMMV
Old Dec 26, 2007 | 08:46 PM
YMMV
sorry but i don't understand, what do you mean by 5mm of stud sticking out the back of my lug nuts?
Old Dec 26, 2007 | 09:20 PM
cthree's Avatar
Administrator
You should be ok with 5mm. Any more and you really should have longer studs.
Old Dec 27, 2007 | 08:51 AM
124Spider's Avatar
I would want substantially all of the threads of my lug nuts attached to threads of the stud, to minimize the possibility of a lug nut working its way loose. You're contemplating moving the wheel 5mm farther away from the hub; prior to doing so, I would want to make sure that I had 5mm of "extra" length in the studs, so that, after doing so, I would still have the entire length of the lug nut attached to threads on the stud.
ATNCHN
Oct 6, 2015 08:26 AM
jdmegtim
Jan 27, 2010 02:19 PM
keemaca
Dec 17, 2009 06:49 AM
astig2k
Apr 19, 2008 02:42 PM
Ajjra
Oct 11, 2004 06:02 AM
