Installing Mugen 3-Piece Spoiler
Old Feb 19, 2006 | 05:05 PM
alejo's Avatar
Arrow Installing Mugen 3-Piece Spoiler
just bought this spoiler and would like to install it myself. it looks from the japanese panflet that you need to drill 2 holes and tape the side pieces...
can anyone help on explaining how to install it, post painting?
thanks
Old Feb 19, 2006 | 06:52 PM
cdelena's Avatar
Most I have seen, including mine, are installed with two sided adhesive body tape, no screws.
Old Feb 19, 2006 | 08:06 PM
alejo's Avatar
thanks for the reply, do you know where the tape was placed? have you had it on for a while?
thanks!
Old Feb 19, 2006 | 10:52 PM
Kel's Avatar
Kel
PM luder94. He's got a 3pc wing. He's like the Mugen PRO.
Old Feb 20, 2006 | 06:43 AM
cdelena's Avatar
thanks!
All mating surfaces are taped for a strong bond. I have had mine on the car over two years with no problems.
Old Feb 20, 2006 | 07:23 AM
Luder94's Avatar
The center portion fits quite snugly to the shape of the trunk. Make sure you have an '00-'03 third brake light. The key fitting it right is using a VERY clean surface, and a mixture of distilled water to plain hand soap (no moisturizers, no scents, etc.). Make the mixture VERY diluted.
After getting the double-sided tape onto the bottom of the wing, spray a light mist of the solution onto the trunk lid. Test mount the center piece of the wing without removing the open side of the tape. Make sure it fits, and then remove the tape backing. Place the wing lightly onto the turnk surface and move it left, right, forward, and back as needed. Once it's in position to where you want it, apply pressure onto it so that it sticks. Now don't move it anymore. Allow the solution you sprayed onto the trunk lid to evaporate.
For the side pieces, do the same as above. Make sure that you leave the trunk lid unlatched, but in the down (near closed) position. As you have one side properly positioned, don't apply pressure right away. Test that the trunk lid with the center piece wing doesn't hit the side piece as you open and close the trunk lid. Once you've positioned the side piece properly, apply pressure to stick the side on. Now repeate for the other side.
You want to make sure that both side pieces have similar gaps from the center piece. If they don't, the center piece will look like it's shifted either right or left even though it may not be.
Also, don't be shy with adjusting the actual trunk and the position it sits in. You can adjust the trunk position by adjusting the mounting location, and at the trunk latch.
Old Feb 20, 2006 | 07:30 AM
alejo's Avatar
thanks kel
Old Feb 20, 2006 | 07:31 AM
alejo's Avatar
awesome help, thanks urmil now i'm off to find an 00-03 center light
Old Feb 20, 2006 | 07:33 AM
Luder94's Avatar
Hey...if you find an '03 light, I'll buy your '04 light off you.
Old Feb 20, 2006 | 07:38 AM
alejo's Avatar
i will dude
