installing new exhaust
Old May 5, 2006 | 11:36 AM
globallyoff's Avatar
Default installing new exhaust
Just what the thread says......my new T1R sparrow should be in by Tues. I'm planning on using antiseize compound on the stud threads on the cat and prob on any exhaust bolts when putting the new exhaust on. Any reason not to? I don't want it to rattle loose, but would like to be able to remove it later if I need to.
Old May 5, 2006 | 12:33 PM
darkfx's Avatar
yes, i used it
Old May 5, 2006 | 04:10 PM
Clayman's Avatar
I can't see a reason not to.
Old May 5, 2006 | 05:54 PM
newspeed's Avatar
i anti seize every bolt that is exposed to the elements.. it never hurts..
Old May 5, 2006 | 08:15 PM
gomarlins3's Avatar
Good idea, just in case you want something different later.
Old May 5, 2006 | 08:27 PM
stphotographer's Avatar
Won't the heat from the exhaust just burn away the anti-seize?
Old May 6, 2006 | 03:54 PM
The heat from the exhaust will burn away the grease part of the compound but it leaves behind little solid particles of aluminum, silica, and graphite. That's how it works. You most definitely want to use this stuff on spark plug installations.
Old May 6, 2006 | 11:05 PM
newspeed's Avatar
Old May 6, 2006 | 11:10 PM
newspeed's Avatar
back when i was into DSMs (98 eclipse GSX) i remember taking apart turbo and exhaust parts and it was a nightmare... when i put my new set up on i anti seized every bolt... about a year and a half later i had to take it apart again and i was like butter taking all the bolts apart...
I love the stuff and never neglect to use it... Like i said earlier it never hurts
Exception: be careful with this stuff around 02 sensors if any of it touches the actual sensor part it will ruin it ASAP...
Old May 7, 2006 | 09:36 PM
zpeed's Avatar
Use it. I also use it on all my lug nuts
