Installing SRS "Fix"
Old Aug 5, 2010 | 07:35 PM
S2KVITO's Avatar
Default Installing SRS "Fix"
SRS light wont go off after installing an aftermarket steering wheel. I have a Works Bell SRS fix tired resetting it and installing it still throws the light, any advice tips or tricks to turning it off?
-Thanks Vito
Old Aug 5, 2010 | 09:03 PM
S2KVITO's Avatar
Anyone?
Old Aug 6, 2010 | 03:42 AM
Billman250's Avatar
Active Streak: 30 Days
Active Streak: 120 Days
Top Answer: 1
If the code has been been set, killing battery power will not reset it.
It can be reset with a paper clip, by using a yellow connector located by the under-dash fuse block.
Read the repair manual. It describes how to do it. Involves momentary grounding of the connector in a few different intervals.
Old Aug 6, 2010 | 11:57 AM
S2KVITO's Avatar
Thanks billman I mastered the reset with the paper clip lol! I have a srs simulator which came with the hub its basically two female connectors with a 2amp fuse. Once I've reset the srs system should I cut the power and install the simulator? Should that turn off my light for good then? What are your thoughts on this? Thanks a lot!
Old Aug 6, 2010 | 02:22 PM
Billman250's Avatar
Top Answer: 1
yes...install simoulator with batt disconnected.
Old Aug 7, 2010 | 12:17 AM
S2KVITO's Avatar
So apparently works bells srs fixers are two wires with a 2amp fuse connecting them creating no resistance at all (garbage and no fix for srs light). Getting a 2ohm resistor at work tomorrow and trying that thanks guys!
Old Aug 7, 2010 | 02:15 AM
iam7head's Avatar
you can set off the SRS light buy messing with the SRS system, one way to do that is by doing electrical work without taking off the battery leads.
for example: if you remove the seatbelt sensor without taking off the battery the SRS will trip off the SRS light, even if you clip the sensor back it will still requires a reset(10 second job)
the same applies to the steering wheel, once you break the circuit by removing stuff from the wheel(airbag itself) it will trip off the SRS light. before you throw away the SRS fix, try to install it and reset the SRS unit first.
not sure what exact was the honda ohm but for my miata, all you need is a piece of wire
Old Aug 7, 2010 | 04:38 AM
01YLWS2k's Avatar
Talking
What's up man, I was wondering if you ever found someone to trade your lights with, I would really like to do this.
Old Aug 7, 2010 | 04:54 PM
S2KVITO's Avatar
The SRS reset is simple did that til I saw it blink twice installed the srs thingy, then took my keys out plugged in the yellow connector to the fuse panel and started the car still srs light
I'm having trouble getting the light to turn off still please help
Old Aug 8, 2010 | 08:56 PM
S2KVITO's Avatar
Still cant get the light to go off i've got the SRS fix plugged in and tried the reset with the plug at the fuse panel idk what to do.
