Intermittent Engine Failure
Symptoms don't seem to align with typical thrust washer bearing seize. Usually engine abruptly dies altogether, and won't restart or even crank over until hours later. Engine totally seizes up.
His restarts on its own from its own momentum. It basically push starts itself.
Clutch Master 3
There seems to be no specific event or condition that precedes the failure, and no pattern of repeats after an event. I'm kind'a like, "WTF?"
I'm going to pursue a new ECU and a new tune to see if I get this fixed. 8-)
That kit's pressure plate has increased clamping force over the OEM one. Correct?
Higher pressure pp means you should definitely do clutch interlock bypass. Each engine start is putting excess wear into this weak link inside our engines.
You should definitely:
1. Do bypass (several options, from paper clip to wiring to another switch, like brake pedal), so can start without pressing clutch.
2. Get an oil sample to make sure you haven't already caused significant damage.
None of this is likely related to your current issue, as problems with thrust bearing typically cause full engine seizure. Then it goes away on its own after several hours. Will do this a couple times before it fully seizes and causes irreversible damage.
But you're not seeing full on seizures that last hours. Above steps will make sure that isn't your eventual future.
silversonic
Sep 27, 2002 10:40 AM
