Which Iso Contacts?
Hello,
i have a problem, i dont know which i use the Iso Contacts for the Ecu Plugs.
This maybe?
http://www.ebay.de/itm/KONTAKTE-fur-...item415e7666a0
I tried some today but many do not fit
Thank You.
This maybe?
Thank You.
The plug housings and contacts are made by TE Connectivity and are part of their 040II/070II Hybrid Plug Series also known as MultiLock. You will need to source contacts specifically for that series and make sure you have the crimper designed to crimp that contact. It should be along the lines of these. I order some of the stuff to build my own plug and play harness for an Apexi AFC but never got around to finishing it because the parts were very hard to get small amounts of and that crimper is expensive. I ended up getting the correct plug housings from TE as samples but thats as far as I got. You could possibly source the parts from someone who builds aftermarket harnesses (like ChaseBays).
Forgottens2k
Dec 11, 2015 03:34 AM
u_tal
Jun 22, 2005 01:42 AM
