it's cold....
Old Feb 8, 2010 | 11:28 AM
PRB2000's Avatar
Default it's cold....
my heater won't work unless i'm on the highway (60MPH), is this the heater core going bad or the thermostat sticking?
Old Feb 8, 2010 | 11:59 AM
s2k dre's Avatar
Check ur coolant level, and make sure the heater valve is fully opening.
Old Feb 8, 2010 | 12:03 PM
PRB2000's Avatar
coolant has been fine, where's the heater valve? under passenger dash?
Old Feb 8, 2010 | 12:08 PM
s2k dre's Avatar
next to the header on the pass side.
Old Feb 8, 2010 | 12:28 PM
PRB2000's Avatar
i'll check it out... thank you
Old Feb 11, 2010 | 03:24 AM
KhushbuMalik's Avatar
Hi,
So, have you checked it? Is your heater ok now?
Old Feb 11, 2010 | 07:06 AM
spectacle's Avatar
There is a motorized valve on the pass side next to the hose that loops back into itself at the firewall. Have someone inside the car turn the temp control from cold to hot and ensure that the valve moves all the way. I had a problem with no heat and thought I had a coolant problem...turns out the heat shield from my turbo setup was blocking the valve from opening all the way
Old Feb 11, 2010 | 07:07 AM
spectacle's Avatar
Caveat...my heat didn't work at all. Didn't matter how fast I was going. Your issue may be different.
Old Feb 11, 2010 | 08:51 AM
XScarAudio's Avatar
By not working, do you mean that the fan isn't blowing? Your description sounds like at 60mph, the incoming air is moving fast enough to move the heat (assuming recirculation is OFF).
Old Feb 11, 2010 | 01:42 PM
Kirpich's Avatar
Check fuses.
