Jack Stands Question
Old Aug 7, 2010 | 03:30 PM
climhazzard's Avatar
Default Jack Stands Question
Hi all,
This may seem like a ridiculous post, but I'm new to working on my own car and want to be as careful as possible . I bought a hydraulic jack and 4 stands so I can do basic maintenance to my car (fluids). The jack stands are "Torin" brand purchased from Northern Tool and are rated for 2 tons. The concern I have is about warnings printed on the box:
"Stands are not to be used to simultaneously support both ends or on side of a vehicle."
"Center load on saddle prior to lifting. Use as a matched pair to support one ends of a vehicle only."
I'm not sure if this is just ambiguous wording which means you're only supposed to use two jack stands on a vehicle period, OR if it means do not try and lift both ends up with two stands. Is there anything wrong with having a vehicle
completely off the ground on 4 stands? Did I just buy crappy stands?
Old Aug 7, 2010 | 03:38 PM
spets's Avatar
You're fine. Two tons is 4,000 pounds, and our cars weigh ~2,900. So you're quite safe to have the whole car off the ground on four stands.
Old Aug 7, 2010 | 03:51 PM
zeroptzero's Avatar
I think it is a warning not to use 2 stands to support the vehicle or one side as that can be unstable. Using 4 stands should be fine though, and make sure the car is always level to avoid the vehicle sliding off the stands. Using 2 stands on the front or rear can result in the car sliding off the stands, so use 4 stands all the time and with a level vehicle.
For further safety slide the wheels under the rockers on both sides, or some other hard object as a precautionary protecting device in case the car ever slid off the stands. You can use a jackstand for this as well, with it placed just under the vehicle but not loaded onto the stand. I actually place 2 more stands under the front and rear center lift points for added insurance, so I have 6 stands in total. I hate creeping under vehicles so I got a bit overboard for safety just in case, we've lost members on this forum due to unsafe vehicle supporting procedures. You can't be too safe.
Old Aug 7, 2010 | 03:56 PM
Thank you for the helpful replies. Jfusion are you saying it is dangerous to only use two stands on the front or rear? I did get two wheel chocks to use on the back wheels when I am only lifting the front up for oil changes. I assume this should mostly eliminate the risk of the car sliding off the stands?
Old Aug 7, 2010 | 03:59 PM
OMGJDM's Avatar
agreed....you can never be too safe while being under a car. one little slip or mistake and your life is at risk. take your time and make sure it's secure.
Old Aug 7, 2010 | 05:15 PM
zeroptzero's Avatar
[QUOTE=climhazzard,Aug 7 2010, 07:56 PM] Thank you for the helpful replies.
Old Aug 8, 2010 | 01:38 PM
fl_speed001's Avatar
I never go under the car unless it is supported by 4 jack stands. My process is pretty much identical to what is posted above. You might think that is a bit overkill for a simple oil change, but is it really worth the risk? If you don't have a stock intake you can probably change the oil/filter without lifting at all...I can with my K&N intake.
Old Aug 8, 2010 | 05:06 PM
ans2k's Avatar
yep with the aem v2 at stock height. i didnt have to lift the car at all.
Old Aug 8, 2010 | 07:52 PM
Thanks for all of the advice. I'm going to pick up two extra jack stands so I have a total of 6, and place the 2 extras on the front and rear jacking points as suggested.
Do you all think having stands rated for 2 tons is adequate or I should get stands rated for 4 tons? I know the car is only 3000 pounds but is it good practice to be using ~75% of the stands capacity?
Old Aug 10, 2010 | 07:21 PM
RedY2KS2k's Avatar
So when you put your 3,000 lb car up on a single 4,000 lb jackstand, where do you put that single stand to balance the car so the stand will be loaded to 75% of capacity?
