J's Header
Old Jan 26, 2006 | 09:23 AM
2 fast for u's Avatar
Default J's Header
I just received my J's header and I
Old Jan 26, 2006 | 01:20 PM
WalkingDrunken's Avatar
I can't say for the EGT sensor but the install for the header should be generally the same. There is no major changes in design so you can follow them.
Old Jan 26, 2006 | 03:44 PM
Thanks a lot, but actually this header seem to have wider runners. I'm afraid I will get the header out and then I cannot get the new one back in.
Old Jan 26, 2006 | 05:16 PM
503s2k's Avatar
I'm just curious why do you need the EGT gauge for your car? Your car is NA then why would you bother install one? Correct me if I'm wrong.
Old Jan 26, 2006 | 08:23 PM
Slows2k's Avatar
If it was a turbo car, a J's header would be useless.
xviper's directions will work, if you install it from the top.
If you choose to install from the bottom of the car, removing the engine mount gives you the room needed to get some headers in. (Toda and Comptech)
Old Jan 27, 2006 | 05:22 AM
I'm Charged rigth now with 389RWHP, and I just want to have this for monitoring purposes.
Old Jan 27, 2006 | 05:23 AM
If you choose to install from the bottom of the car, removing the engine mount gives youthe room needed to get some headers in. (Toda and Comptech)
Thanks a lot I will follow Xviper instructions.
Old Jan 27, 2006 | 10:14 AM
Trip's Avatar
389RWHP from a S/C assuming you are changing the header. Nce # for a S/C
What psi are you running ?
I helped a friend out replacing a header. It was a Rick's + 2
We put the thing in from under the car, We had to lift car around 3feet.
Old Jan 27, 2006 | 02:09 PM
APEXSEAL's Avatar
I installed mine from the bottom and without removing the engine mount.
Old Jan 28, 2006 | 11:11 AM
Thanks, I
