Just changed front control arms.
Old May 5, 2005 | 05:50 PM
tizbad2k's Avatar
Default Just changed front control arms.
I needed to change the front lower control arm because my mech told me that it was bent and that it needed to be changed, he also suggested upper arm , but said he wasnt sure if that was necessary, both of these parts were junkyard parts that the prevoius owner had put on after a wreck.
I got the set of upper and lower arms, though a member of this board.
And took out these:
YOu can see in the following pic what was bent, the curve on the lower half of it should be the other way.
These are the bushings of the old lower arm.
I finished at 8:30pm and rushed to see if i could get an allignment, but im gonna have to wait till tommorow morning. The car does fill different in a better way though, even though my allignment is all screwey i felt some handling difference, btw i also installed the missing sway bar endlink.
Streets2Kanyons
May 15, 2017 03:49 PM
tsatsj
Ηλεκτρικά Θέματα
20
Jan 20, 2016 12:29 AM
ARM1N
Aug 19, 2012 06:59 PM
Fapout
Oct 30, 2003 09:43 PM
