just did a compression test
Old May 3, 2009 | 12:17 PM
sigmanin's Avatar
Default just did a compression test
so my local shop just did a compression test on my car. i was planning on turboing it very soon and wanted to make sure of a health engine before i did anything.
well it sucks balls.
my compression
cyl 1 220
cyl 2 230
cyl 3 210
cyl 4 180
what do you guys think about it.
i know cyl 4 is reading kinda low but the odd thing is the car runs very smooth and i dont even notice a diff when i campared it to a friends s2000 in driving feel and accel power.
my car is a 02 with 125k miles. from what ppl are telling me i should try a topend cleaner to see if maybe one of the valves on cyl 4 has some buildup around the vavles and not closing properly
just wanted to see what you guys think and get any advice. i might just build my engine but not really looking for crazy hp even when i turbo im only looking for maybe 400whp at most off of a gt30r
Old May 3, 2009 | 02:00 PM
ahrmike's Avatar
400whp means youre basically doubling the power from stock.
Old May 3, 2009 | 05:54 PM
camuman's Avatar
u can try something like seafoam, but dont get your hopes up. might be time for a rebuild. you would need to do a leakdown test to see where the problem is.
Old May 3, 2009 | 08:05 PM
starchland's Avatar
i wouldnt worry too much. if your car feels great then dont worry about the numbers. however if your turboing it may lead to problems. you could try a top end cleaner and an oil flush and retest but it just sounds like normal wear on a high mileage engine.
Old May 3, 2009 | 08:59 PM
sigmanin's Avatar
yeah a top end cleaner is what im planning next to see how it goes and redo a compression and leak down test.
if its the rings i might just build it. im just trying no to do any over kill when i do it.
if it is the rings im still debating on what i should do. if the pistons and rods look good should i just replace the rings and do a 3mm hg or should i go for some lower commpression pistons while i have the engine cracked open. im leaning trards the low comp pistons as they will not cost much more then a 3mm hg and they will be out anyways when new rings get put in.
its not that i want to go cheap or anything. money isnt that important as this is my toy and dd during the summer when it nice out. i have a wrx for winter and people carrying. but i just dont want to overkill to much on anything as the engine will see 10-12 psi most of the time and maybe a bit more on high boost if and when i take it to the track.
if i went with a 3mmhg i might just get new stock rods and pistons as they are pretty cheap. or i would go with low comp pistons and maybe new aftermarket rods with w reg hg.
if i went with low comp pistons i would need to resleeve as well correct?? well even if i didnt need to i might as well lol. but im just feeling that is over kill. because from what i have read on here a 3mm hg can be taken to 400 hp without much problem and some have gone much higher then that to the 500 hp range.
hmmm maybe i should have started this in the fi section.
Old May 4, 2009 | 05:33 AM
lotus7racer's Avatar
Drop some oil in cyl 4. Then,take the compression. If the compression goes higher than 180, for sure the ring is bad.
400hp? that's a lot of zhyte. Turboeng a hi-compression engine without
lowering the compression is asking for trouble.
The rest of your compression is fine but not great in a turbo spec.
The s2000 engine is not meant for turbo. I think you should hone the cylinders, install a new rings then use a thicker head gasket. Although this is a half ass job, but far better than what you did (installing a turbo without lowering it).
Old May 4, 2009 | 06:00 AM
IlleztImportz's Avatar
what is a topend cleaner?
Old May 4, 2009 | 07:20 AM
devs2k's Avatar
i'd say sleeve the motor and get some low comp pistons
Old May 4, 2009 | 08:57 AM
spectacle's Avatar
Please stop posting false information. Please.
Old May 4, 2009 | 09:04 AM
I will be glad and will apologize if you tell me which false statement.
...explain
No single word like your post.
