Just did my compression test
Alright so I followed this guide http://robrobinette.com/S2000Compression.htm and did my first compression test.
My results on a warm engine with full throttle and fuel fuse removed were:
1: 225-230
2: 210-215
3: 220-225
4: 235-235
From what I've read I understand 240+ is best, but consistency is also important. I'm a little concerned about the range of readings I got here, mostly with cylinder 2. I did recently do a valve adjustment and am beginning to wonder if maybe I had the valves a little too tight or too loose on C2?
car is an 06 with 89k miles.
What do you guys think decent results or should I continue with a leakdown test and perhaps recheck my valves? I will say prior to the valve adjustment it seemed most of my valves were far too tight.
1: 225-230
2: 210-215
3: 220-225
4: 235-235
Those numbers are very good actually. Usually people begin to worry when the compression test is 10% off from each other. I personally would recheck the valves because I would not want to have them on the back of my head and also do a leak down to confirm that the engine is healthy (which it probably is).
Cylinder 2 seems low compared to the rest, but not bad at all for the motor in general. I would do as you thought, check the valves again and make sure those are good. Then redo the test. If the 'issue' (not necessarily an issue) persists, a leakdown test might be in order.
