Just install comptech supercharge and got this code
Old Feb 17, 2004 | 08:06 PM
Slows2k's Avatar
PCM=ECM= The cars computer
Old Feb 17, 2004 | 08:08 PM
jays2000's Avatar
Slow i must say thanks a lot for your help for me i will check everythign up again
Old Feb 17, 2004 | 08:39 PM
AusS2000's Avatar
Did you do the SC/E-manage/ESM install all at once, or was the car running with the E-manage previously?
Not sure whether this is an E-manage issue (setup and wiring) or just a general wiring issue.
If you have looked into the E-manage properly you should be aware that it makes the ESM obsolete.
Please provide more info.
Old Feb 17, 2004 | 09:06 PM
jays2000's Avatar
Guy i solve the problem now thanks a lott for all of you. specially slows2k. I found out that i should take off all the wire from the previous Emanage and the car start like normal now thank you all
Old Feb 17, 2004 | 09:10 PM
AusS2000's Avatar
The car will run fine with the Comptech kit including ESM, but the E-manage is perfect for tuning the setup so I'd recommend putting it in and getting it tuned.
I currently run a Comptech SC with smaller pulley, E-manage, bigger injectors and have removed the Comptech FPR.
jordannn93
Oct 10, 2011 11:22 AM
04RioS2k
Nov 14, 2005 09:29 PM
home13oy75
Aug 31, 2004 12:39 PM
SpeedTheory
Aug 14, 2004 05:45 PM
NMs2000
Aug 8, 2003 09:42 PM
