just a quick question about rear subframes
Old Oct 3, 2007 | 11:53 AM
NexS2000's Avatar
Default just a quick question about rear subframes
is the ap1 and ap2 subframes identical? can it be swapped out without modification.
Old Oct 3, 2007 | 12:36 PM
slipstream444's Avatar
I believe the AP2 rear subframe will bolt up to an AP1, but I think there are a few differences.
I believe some of the rear suspension geometry changes are addressed in the rear sub frame of the '04 and later. Someone correct me if I'm wrong please (I can't find where I read that previously).
Old Oct 5, 2007 | 07:47 AM
TrackStar's Avatar
I've done the swap. Totally bolt on, but you need new rear upper control arms. Makes the car handle better
Old Oct 5, 2007 | 08:08 AM
How difficult is the swap?
Old Oct 5, 2007 | 08:58 AM
jyeung528's Avatar
i'm curious too...and what is the approximate cost of the rear subfram and rear upper control arms?
thanks...
Old Oct 5, 2007 | 09:13 AM
TrackStar's Avatar
The swap is easy, but time consuming. Took me about 5 hours with the car on jackstands. I got the subframe for like $280 shipped iirc and the control arms were like $180 shipped. I think it was worthwhile mod.
Old Oct 5, 2007 | 09:35 AM
Where did you source the subframe and control arms?
Old Oct 5, 2007 | 09:48 AM
jyeung528's Avatar
that's less than the price of the toe arms from TC Design...
so my choice is...ap2 rear sub frame and upper control arms...or...TC Design toe arms.
which is better to reduce toe deflection/bumpsteer...
Old Oct 5, 2007 | 09:02 PM
TrackStar's Avatar
I have the subframe, control arms, and the Megan arms
Old Apr 7, 2008 | 11:13 PM
Antonov's Avatar
Originally Posted by hecash,Oct 5 2007, 09:50 PM
The rear subframe is common for:
2000-2003
2004-2005
2006-2008 including the CR
The rear lower arm is the same for all years.
The rear upper arm is common for:
2000-2003
2004-2008 including the CR
sorry revive old thread, I have a question.
So the 04-5 rear subframe is different from the 06+, what are the differences?
Are there any differences in the rear uprights?
-Dino
