Just Weight the GT-U
Old Jul 4, 2003 | 09:06 PM
jays2000's Avatar
Default Just Weight the GT-U
Hi GUys
I just weight the GT-U without tires the weight so impress me a lot. The front 18*7.5 = 10 pound Rear 18*8.0 = 10.2 Pound sooooooo light.
Old Jul 4, 2003 | 09:36 PM
MrForgetable's Avatar
Hi!
are you sure it's not 10 and 10.2 kilos? cause 10 pounds for a wheel is LIGHT, and an 18" wheel, almost impossible to find, but if it is 10 pounds, that's an amazing wheel.
Old Jul 4, 2003 | 09:50 PM
geminiS2's Avatar
how much do stock wheels weigh
Old Jul 4, 2003 | 09:55 PM
spider's Avatar
Almost 18/19 lbs, front/rear.
Old Jul 5, 2003 | 12:40 AM
hyperpm's Avatar
10 lbs for 18" Volks? From evos2000 post he mentions that these are 19-20 lbs each.
Old Jul 5, 2003 | 01:17 PM
Spankee's Avatar
I know they arent that light.....I didnt weigh them buy I did compare both side by side and the GT-U's with tires are pretty much close to the weight of the stock wheels and tires.
Old Jul 5, 2003 | 02:44 PM
Wildncrazy's Avatar
Nice rims! What offsets? What finish? (they've got so many different names for their finishes)
I thought stock rims weighed 16-17 pounds. Was I wrong?
Old Jul 5, 2003 | 03:50 PM
Penforhire's Avatar
That sounds unreasonably light. I thought 12.5 lbs was the lightest set of sturdy rims for our cars (and that's in stock size). I know 10 lbs is the weight for similar-size racing aluminum rims (that I would NEVER put on a daily driver).
Old Jul 5, 2003 | 07:00 PM
Wildncrazy's Avatar
The latest issue of Turbo has a number of lightweight rims compared. I did not see the GTU, but the xx37K looks very simiar.
To give you an idea of the weight ranges:
VOLK
CE28N 17 x 7.5" = 13.6 lbs.
CE28N 18 x 7.5" = 16 lbs.
SE37K 17 x 7.5" =14.2 lbs.
SE37K 18 x 8.5" =16.2 lbs.
LE 37K 17 x 7.5" =14.8 lbs
LE 37K 18 x 7.5" =15.6 lbs
(what's the difference between the SE & LE? They look the same except for the finish except they aren't the same weight)
TE37 17 x 7.5" = 15.6 lbs
TE37 18 x 7.5" = 17.2 lbs
Gram Light 57C 17 X 7.5" = 15.8 lbs.
VELOX PROGEAR
PG-REV8 17 x 7"= 12.4 lbs.
PG-REV5 17" x 7" = 12.6 lbs.
PG-REV10 17" x 7" = 12 lbs
PG=REV7 17" x 7" = 12.4 lbs. (divided spokes - nice touch on a 7 spoke wheel)
VX-6R 17 x 7" = 14.4 lbs.
RH EVOLUTION CP8R 17 x 7" = 12.4 lbs
Old Jul 5, 2003 | 07:57 PM
jays2000's Avatar
Here is what can solve all the issue
