k24 crank in f20c
Old Jan 28, 2006 | 11:46 PM
Vladimir L's Avatar
Default k24 crank in f20c
Will it work?
I know cranks from honda run around 680 bucks...
a full after market piston set 500 bucks...
Old Jan 29, 2006 | 02:16 AM
slipstream444's Avatar
Originally Posted by Vladimir L,Jan 29 2006, 02:46 AM
Will it work?
Although the search function on this page is not that effective ... you should at least make an effort and use it - because this has been covered several times (K series parts on an F series motor - or Vs Vsa).
The plug and play answer is NO.
Old Jan 29, 2006 | 10:28 AM
steven975's Avatar
I also suspect K24 internals are not anywhere near as balanced as F series internals. I'd guess 7500RPM will be your max, reliable RPM.
Old Jan 29, 2006 | 10:31 AM
Emil St-Hilaire's Avatar
Active Streak: 30 Days
Forget the project.!!!
Old Jan 29, 2006 | 10:57 AM
[QUOTE=steven975,Jan 29 2006, 01:28 PM] I also suspect K24 internals are not anywhere near as balanced as F series internals.
Old Jan 29, 2006 | 11:10 AM
Slows2k's Avatar
Look up inline-pro's 2.5 liter. Rumor has it a K24 crank is used. inline pro also removes the oil jets that spray cooling oil at the bottom of the pistons to make it work.
The 2.5L's has had an exceptionally high failure rate.
Old Jan 29, 2006 | 02:07 PM
steven975's Avatar
the k24 crank is also meant to be used with twin balance shafts. that is something the F block doesn't even support.
I would believe that is why the 2.5s fail so much.
Old Jan 29, 2006 | 03:27 PM
f20kills's Avatar
I dont know how motors work, but what happens if you bore it out and add 2.2 f22 crank?
Old Jan 29, 2006 | 04:47 PM
Vladimir L's Avatar
Yeah im thinking about just using the F22 crank and high compression pistons
Old Jan 29, 2006 | 05:14 PM
s2kboost's Avatar
when u say k series do u mean the new rsx motors
