key wont turn while in ignition
Symptoms are: Key will go in, but will NOT turn forward at all.
The problem started a month ago, i had to play with the key in and out the ignition and was able to start the car but now it take me up to 20min hehe. I tried grease, i try the 3 keys i have, nothing work.... whats the cheapest way to fix that ?? new ignition switch from honda ? used key and ignition or a locksmith ??? anyone can help me ?? |
Originally Posted by tsukubaSpec
(Post 21814331)
The problem started a month ago, i had to play with the key in and out the ignition and was able to start the car but now it take me up to 20min hehe. I tried grease, i try the 3 keys i have, nothing work.... whats the cheapest way to fix that ?? new ignition switch from honda ? used key and ignition or a locksmith ??? anyone can help me ?? try to crank the wheel one direction and turn the key at the same time. try both sides. hope this is just a simple problem! |
i tried everything hehe i know its time to replace the ignition switch, just hope someone can chimie in and tell me whats the cheapest way to fix that problem.
My BB6 Prelude was doing this. The slots in the centers of the waffers in the tumbler get worn down from the key sliding in and out of them. I disassembled the ignition tumbler and filed down the outsides of the waffers that were not retracting into position fully when the key was inserted. I would imagine you could get new waffers from a locksmith or have a locksmith do the whole thing for you.
mechanical ignition switch is going bad/worn. do you have many keys on your key ring? I keep minimal keys to help keep excess weight off the ignition. Might be able to get a locksmith to "rebuild" it. I had this happen to one of my other cars
tsukubaSpec ,I am running the exact same problem. Key goes in but it wont turn. I tried moving the steering wheel, greasing the key , everything.
, did you get it fixed? and how? thanks |
Lock-ease graphite lube no help?
