Keyless trunk popper works, trunk switch inside doesn't
For a while now, my switch inside to pop the trunk hasn't been working. The fob/keyless trunk popper works perfectly. I have researched on this website. I tore down the loom on the drivers side of the trunk arm, all wires are intact. Inspected fuse 26, checked fine. Looking through my HELMS manual and I am hitting a wall. I've tested the trunk popping switch and it passes.
I replaced the entire soft top and frame. During the install and swap, all worked. It's been a while but I believe the interior trunk switch worked even after the top install.
Any and all guidance is greatly appreciated. Thank you for your time and experience.
It seems most likely the glovebox switch connector has become unplugged, as a result of spft top install.
Either it was never plugged in at all, or not plugged securely and has since fallen off.
Keep using fob until you can find an excuse to remove panels to plug it back in.
Problems with the trunk unlocking can often be found in the condition of the wire bundle leading from the latch to the inside of the car. Take a close look where it makes the turn between the lid and the trunk. Constant flexing will cause the wires to break, short, and fail.
I wish I had more to offer. When I read the recent suggestion to look at trunk wiring, my thoughts were Dhuh, sure its a common issue, but not if it works perfectly 100% of time from fob, and only interior trunk switch isn't working...
But then I thought who knows if for some weird reason the interior switch and fob switch don't both unlock in the same manner using the same wires into trunk. It would indeed be a weird design, but since its so easy to check the trunk wiring, it would be worth ruling it out at this point.
My personal troubleshooting approach os when you reach the point where things don't make sense, its worth looking at things that don't make sense. Often the result is discovering something completely unexpected that adds a new, important clue, that opens a new path which ultimately reveals the solution.
When things get weird you gotta get weird...
I appreciate all input Car analogy! I've let it go for a while because I assumed it was the wiring, but when I noticed how clean and completing together it was, it shot that idea right in the foot. After checking the trunk switch in the glovebox, it was perfectly fine, I checked the fuses visually speaking, those all looked good. I am going to get under there with a test light and triple check.
While replacing the top, I did my best to ensure all wires were out of the way before bolting things down. At the end of the day we are all human and possible that I caught a wire. Gonna have to do more digging. Most likely have to remove the drivers side hoop and plastics. Then the inner door plastics to the ECU. Fairly short wiring path so hopefully it will be an easy find.
The HELM has a wiring diagram with the trunk switch and the key fob. To me, it looked like, if there was a break in the wiring, the fob wouldn't work either. But it works 100% of the time. Crazy.
