kg/mm super sport...which end is up?
Once you get the car apart, you'll realize that there is only one way the springs will fit. The smooth end (where the spring tapers off) should be on the top, and the end where the wire just suddenly ends fits on the bottom in a specially shaped craddle. The top has a slightly smaller diameter too I think?
Chris.
Chris.
Originally posted by Hockey
What they said.
Just make sure there is no difference from front to back, like my Eibachs!
What they said.
Chris.
Originally posted by chrisr111
If you weigh them, the fronts should be lighter than the rears.
Chris.
Chris.
Chris.
After like 8 hours I finally finished installing the springs.
I think thie setup looks way better than the neuspeed's that I used to have. We'll see how they ride.
Thanks for all the info fellas.
