Knock noise when i reverse
Old Apr 5, 2020 | 04:42 AM
Velvet99's Avatar
Default Knock noise when i reverse
Any ideas on this. when i reverse there is a knock which i thought might be a bush etc however on inspection of MOT my mechanic noticed a small amount of backlash on the diff. Has anyone else had this knock which is connected to the diff. If it is the diff then i need to find the right guys to sort it. Any ideas thoughts and recommendations would be appreciated
thanks
Old Apr 5, 2020 | 06:26 AM
Billman250's Avatar
Active Streak: 30 Days
Active Streak: 120 Days
Top Answer: 1
If you mean a single knock when reversing, look up axle nut tsb. Insufficient axle nut torque.
There is no way dif backlash is causing a knock.
Old Apr 5, 2020 | 08:34 AM
zeroptzero's Avatar
Wait a fraction of a second when shifting from a forward gear to reverse, or double clutch, see if that helps. Sometimes I noticed a knock shifting into first gear too quickly when coming to a stop, same idea I think. It's not a maintenance issue.
JoePhotographer
Apr 30, 2019 04:34 AM
Curated Content Editor
May 15, 2018 08:32 AM
A 2
Oct 24, 2016 07:24 AM
