LE 607...is it GL5 rated???
Old May 16, 2004 | 09:36 AM
  #21
Road Rage's Avatar
[QUOTE]Originally posted by Legal Bill
Thanks once again RR.
Old May 16, 2004 | 07:20 PM
  #22
Legal Bill's Avatar
[QUOTE]Originally posted by Road Rage
Old May 18, 2004 | 03:35 PM
  #23
Road Rage's Avatar
No, Bill, I am fine with you* - I just read very carefully, and forget others do not, or just browse or scan. You have the info you need. If you ever get a case on you, I can appear as an expert witness on your behalf!
*I got a xviper maddening post just tonight, from someone who literally asked me how to shift and drive fast through corners and control skids. I am supposed to educate via proxy? I sent him to school, literally.
Old May 18, 2004 | 05:23 PM
  #24
oakfloor's Avatar
thanks for info on my amsoil gear lube. can you tell me why this is not a good choice for my tranny? thanks.
Old May 18, 2004 | 07:45 PM
  #25
honda606's Avatar
Ultimate confusion here.
Wasn't this already covered in this same exact thread and you yourself already said you were going to drain it and switch it out with Redline MT-90 transmission fluid? I don't understand at all what you're wanting to know that hasn't been said already?
The AMSOIL gear lube you put in your tranny is a GL-5 differential fluid. GL-5 is typically not good for trannies.
I really don't know how much more simple to put it than this(I now see why RR is getting so annoyed with the PM's):
GEAR OIL/LUBE/FLUID(whatever you want to call it) GOES IN THE DIFFERENTIAL
TRANSMISSION FLUID GOES IN THE TRANSMISSION
Gear oil/lube/fluid is NOT transmission fluid
Use Honda MTF, Redline MT-90 or MTL, GM Synchromesh or whatever floats your boat in your TRANSMISSION
Old May 20, 2004 | 04:18 PM
  #26
Road Rage's Avatar
RR, do you know if amsoil 2000 gear oil is a GL-5 ? I just replaced both trans and diff with stuff. thanks.
Yes it is. But it is a bad choice for your transmission! This has been posted over and over again - if one is going to 2nd guess Honda, be very sure of what you are doing.
I concur with what honda606 has written in his response to you. I would get that Amsoil out of your tranny ASAP.
Old May 20, 2004 | 04:41 PM
  #27
oakfloor's Avatar
RR, thanks I have 2 qts of redline mt-90 on order.
s2000nnj
Feb 25, 2011 03:11 PM
JEEBS
Sep 27, 2008 07:31 AM
Slick2K
Sep 5, 2008 03:12 PM
Empedocles99
Feb 17, 2007 07:04 PM
Lunacy
May 30, 2003 10:13 PM
